Mark
Mark
created a new forum post in
General
P50 Rack Card Connector
Maintenance Control request to change one of the card connectors in the P50 panel.
Removed.....
Back cover off.....
Fortunately, the connector slides out the back side.
The
$120+
dollar tool called out in the Standard Wiring Practices Manual.....
vs. the standard green/white plastic....
(I won't be spending any money on the expensive tool.)
View Thread →
© 2023 Rotate.Aero
