Mark
Mark
replied to the topic
Antiskid Control Unit
in
737 Classic
No. If maintenance does their job right. There’s no degradation, only failures of components. Once the fault has been identified and repaired, the system is 100% functional.
If things are failing, you get flat and blown tires.
View Reply
View Thread →
