• Mark replied to the topic Installation of wires in 737 Classic
    Sealing plugs don't really do much inside the pressure vessel. Especially, up front in the electronics compartment where there should be little to no water or hydraulic fluid.
    We plug the holes that don't have wires, but they aren't needed for safe operation of an aircraft.
    If I change a plug with ten unused pins, but they only supplied five plastic plugs.... I'll install what I've got and move on.
