Mark
Mark
replied to the topic
Installation of wires
in
737 Classic
12 wires total. The pins called out are "only" for the plug on the right.
The other side of the wire group goes to different type plugs (which might have different pins).
Those pins must be identified in the Standard Wiring Practices Manual.
I see three jacks and the left and one plug. I know they don't use the same pins.
They could be male or female. Larger or smaller diameter.....
This post:
Pins/Splices/Terminals
Might help you out.
Direct Link
rotate.aero/images/Basics/Tools_Pins_Sockets_Term.pdf
View Reply
View Thread →
