• Mark created a new forum post in ATA 49 APU
    From member Emblem DHC.....
    Currently on OUR Embraer legacy 600 we are facing a serious problem with APU ( APU SHUTDOWN AUTOMATICALLY)
    Aircraft is serviceable it's APU FADEC Is removed for another aircraft and when we installed new APU FADEC APU start shutdown automatically after 1 hour of operation
    So we check APU FADEC FAULT Message
    1. SPEED SENSOR FAULT ( AS per this SPEED SENSOR CHANGED)
    2. SYSTEM B/U OVSPD ( BACKUP OVERSPEED) AS per this  FCA Fuel control assembly changed , fuel soleniod valve , APU Engine harness swapped)
    But actual there is no OVERSPEED
    Now problem becomes worse APU Start shutdown after 3-10 mintues,
    Sometime in start cycle , sometimes work for 1 hour
    One thing we notice RPM is increasing slowly after reaching 95
    It's slow down  its like 96, 97then back to 96 and then increase to 100
