Mark
Mark
replied to the topic
Automatic Pitot Heat
in
Member - Dynamics
From your last email..... I already know the answer.
Your WDM, IPC, and Equipment List show the power contactors as "breakers".
This is a naming issue. Circuit breakers as commonly referred to are.....
Contactors (called breakers in print) are power bus connection devices.
You're getting caught up in nominclatures. Boeing calls them one thing, Airbus another.....Gulfstream another, etc....
They're all the same thing.
View Reply
View Thread →
