Mark
Mark
replied to the topic
Fuel Quantity Indicator
in
737 Classic
The bussing plugs are mounted to the forward wing spar under the Krueger Flaps.
Those flaps can close quickly and take a person's head off.
Any time someone is working behind the flaps, hydraulics should be locked out. Safety lockouts (if you have them) should also be used.
View Reply
View Thread →
