Mark
Mark
replied to the topic
Flight/Ground Idle Issues - CF6-80C2B6
in
CF6-80C2
To eliminate aircraft wiring as a issue, we ran 28VDC directly to the Flight/Ground Solenoid from a DC Power Supply.
When the engine was running, I was able to change RPM's by either appling or removing power to the solenoid.
Using an external power supply for troubleshooting is mentioned in AMM 20-80-24.
View Reply
View Thread →
