Mark
Mark
replied to the topic
WDM-T/S
in
737 Classic
WDM-T/S
I've never heard of the resistor method. Exactly how is to be accomplished (safely) with the engine running?
Just by the fact that the CSD oil pressure light goes out (on the overhead) when the engine is started should prove the switch is operational.
Please..... check out the wiring as described above and on previous post.
View Reply
View Thread →
