Mark
Mark
replied to the topic
ATA 23-51, Yoke Microphone Switch
in
ATA 23 Communication
I was able to help a pilot from another small airline flying 767's in Alaska get the switches installed on their aircraft.
Contact your maintenance engineering department to see if something might be done for you.
As far as cockpit noise goes..... ANR (Automatic Noise Reduction) headsets work great.
View Reply
View Thread →
