Emblemdhc
Emblemdhc
replied to the topic
ELT Buzzer continues on without ELT Activation
in
ATA 34 Navigation
Yes sir ELT is faulty
But second thing is why buzzer only sound when we turn on aircraft battery
as per wiring diagram Buzzer power is provided by ELT then buzzer should always be on even if we turn off the battery
Sir what do you think about it
View Reply
View Thread →
© 2024 Rotate.Aero
