Engine cycles are recorded along with aircraft cycles. It is known that engine cycles are always higher in number. Ground taxi and engine power runs for example.
All official records are aircraft cycles. Engine cycles are recorded from time of install, but they are referenced to the aircraft.
You are flying an older aircraft. It has no means of recording every start. The only time that matters for engines is cycles and flight run hours of which run hours holds more importance.
