Bypass "Binary Pressure Switch" (Jumper it with CB-2 pulled as this is a hot circuit).
The coil in "Motor Power Relay" might be going bad (Opening when hot - closing when cold).
I would think the second is probably more correct. Pull CB-1 and put a meter across the power contacts of relay. See if it opens and closes continuously. That diode shown below the power relay is a Suppression Diode, it could be breaking down also. Most are built into the relay itself.... if not, one side of it can be disconnected for testing purposes.
You said "Auto" position. I see no "auto" on your print.
