| Voltage |
The most common AC voltage systems on aircraft use 115, 26, & 5 VAC. Cycles are 400Hz. Normal power sources are 3 phase engine driven generators or inverters.
One helpful tip when checking power with a meter in AC or DC, is the scale at the bottom of the display. The sample rate for the digit display is not fast enough at times. If voltage is varying or intermittent, the scale is a better source for observing this problem. |
