Flight deck access system
1 month 2 weeks ago - 1 month 2 weeks ago #1851 by dynamics
Please explain what the “flight deck access system controller” is, and describe its function.......
Last edit: 1 month 2 weeks ago by Mark.
1 month 2 weeks ago #1852 by Mark
Replied by Mark on topic Flight deck access system
The main purpose of the flight deck access system is preventing unauthorized entry into the cockpit.
The flight crews can lock/unlock the door with a switch (usually on the overhead panel).
There is a panel on the outside of the door that a numeric pass code that can be punched in to allow the door to unlock.
1 month 4 days ago #1854 by dynamics
Replied by dynamics on topic Flight deck access system
What can be done if the numeric pass code has been forgotten?
1 month 4 days ago #1855 by Mark
I have no clue as to the type of system installed on your aircraft.
This would be a add-on from the the original delivery configuration, so I would think you would find information in a Supplemental Maintenance Manual.
Time to create page: 0.641 seconds
