• Oct-23-2026
    A 767 with a long history of intermittent faults:
    Flickering lights on different occasions.
    Pitot heat Korry Switch lights
    Flt data Recorder off light
    Equipment Cooling Valve light
    F/O air speed V1 and AOA on flat screen
    Since December 2025 has been a problem
    multiple entries and replacement of equipment and harness
    PSEU unit accusing always sensor S267 R/H MLG
    computer will switch from far to near  causing the lights flickering.
    On the Fwd E/E behind the EICAS computers, probably from the a last MOD found 3 clamps pinching wires on a big bundle. This problem has caused multiple AOG and money loss to the company.
    Hours of T/S and man power unknown.
