OG GarlicSalt
OG GarlicSalt
replied to the topic
ATA 26-11, Systron-Donner Fire Detection
in
ATA 26 Fire Protection
Mark did you try to test the loop with a megger once removed? I remember it being a way to find intermittent loop failures but blurb in the manual that the loop must be clean prior to using the megger.
View Reply
View Thread →
