• Emblemdhc replied to the topic APU Faults in ATA 49 APU
    Fault message Recordeed on APU FADEC
    1. SYSTEM B/U OVSPD ( Means backup OVERSPEED) caution
    2. FADEC N1 DELTA ( means there is mistach in both channels of DUAL SPEED SENSOR
    MESSAGE ON AIRCRAFT EICAS WHEN APU SHUTDOWN AUTOMATICALLY ( APU FAIL)
    And AIRCRAFT CMC MESSAGE ( OVERSPEED)
    SAME MESSAGE ALL TIME
    IN APU DC GENERATOR INSTALLED We sawpped the GENERATOR  AND GCU But no results
    We swapped most of the harness but no results
    We also send data to the APU manufacturer they are saying BOTH SPEED SENSOR CHANNEL FAILED
    Already DUAL SPEED SENSOR SWAPPED WITH TWO AIRCRAFT BUT NO RESULTS
    And AIRCRAFT original FADEC IS Also installed but no results
    Now we are clueless BUT WE CAN DO
    ​​​​​sometimes APU Takes start but sometimes not
    Sometimes its work for hours and sometimes even shutdown in 3 to 10 minutes
    First time dealing with this type of snags
