Tire burst/brake failure
1 year 4 days ago - 1 year 4 days ago #1043 by dynamics
Mark, taking all airplane models you have experienced with into account, do you have any idea on most probable culprit for tire burst and brake failure either when it is occurred during take off or on landing, and is there a way for the crew to find out the failure from the flight deck instruments?
Last edit: 1 year 4 days ago by dynamics.
1 year 1 day ago - 1 year 1 day ago #1047 by Mark
Replied by Mark on topic Tire burst/brake failure
Have you looked at  rotate.aero/forum/767-ata32/372-ata-32-42-anti-skid ?
This was after a gear change where the Anti-Skid speed transducers were hooked up to the wrong wheels.
As far as takeoff..... if a crew has a dragging brake, they'll feel it on taxi. I'm sure any anomalies noted would cause a return to gate.
There's a ton of possibilities for faults in the Anti-Skid system. The Anti-Skid Control Unit should be monitoring for the wheel speed transducers, hydraulic pressure, braking valves, IRS speed inputs, air/ground configuration, and others. A failure in any (or the unit itself) should disable the Anti-Skid system and warn the crew that a problem exists.
Last edit: 1 year 1 day ago by Mark.
1 year 1 day ago #1049 by dynamics
Replied by dynamics on topic Tire burst/brake failure
Is there any way to discern anti skid system malfunction from read out data of FDR/QAR?
1 year 1 day ago #1050 by Mark
I'm sure anti-skid has a data label output to the DFDAU, QAR, and FDR.
Time to create page: 0.769 seconds
