ATA 26-11, Systron-Donner Fire Detection
4 years 6 months ago - 4 years 6 months ago #792 by Mark
Most engine fire detection systems come in two forms,  Systron-Donner or Kidde .
CF6-80A and CF6-80C2 that use Systron fire detection systems have three equal resistance loop sensors. Each loop measures 4.5K Ohms. They are wired in a parallel circuit.
In a functional system 1.5K Ohms should be read at the fire detection card pins 19 & 20.
If 2.25K Ohms is read..... you've lost one loop. If 4.5K Ohms is read..... you've lost two.
The "only" way to verify an open loop is to disconnect one (or both) wires from the loop terminals and measure resistance at the terminals (if the wires are connected..... you're reading the other loops and possibly the card).
A loop is either good or bad. There is no halfway. 4.5K Ohms or open.
If a bad loop has been isolated, throwing a decade box across the terminals should at least give you a valid test from the cockpit.
Or..... just throw a 4.5K Ohm resistor across them.
Last edit: 4 years 6 months ago by Mark.
1 month 1 day ago #1902 by Mark
Interesting problem today. The right engine loop 1 was showing as failed on EICAS. The system installed was a Systron-Donner.
1 month 6 hours ago #1904 by OG GarlicSalt
Mark did you try to test the loop with a megger once removed? I remember it being a way to find intermittent loop failures but blurb in the manual that the loop must be clean prior to using the megger.
1 month 6 hours ago - 1 month 6 hours ago #1905 by Mark
I have used a Megger on engine loops, but I'm not a fan of using one.
A Systron loop is pressure filled, so a Megger shouldn't hurt it. The Kidde???? I would stay away from a Megger.
With this problem, after we used the decade box for substitution, the loop read 30MΩ (that was just from removing the one terminal lug).
We smacked the white doughnut pretty hard and the 4.5KΩ returned. It didn't fail after the beating.
I use a regular VOM on most engines loops. A LCR Meter can also be used.
A LCR Meter should "always" be used on body and wing overheat loops.
Last edit: 1 month 6 hours ago by Mark.
Time to create page: 0.782 seconds
