Mark
Mark
replied to the topic
ELT Buzzer continues on without ELT Activation
in
ATA 34 Navigation
If no 121.50 signal, ELT is not activated.
If the buzzer stops when you disconnect the ELT plug going to it..... then it must be the ELT itself.
View Reply
View Thread →
© 2024 Rotate.Aero
