Mark
Mark
replied to the topic
ELT Buzzer continues on without ELT Activation
in
ATA 34 Navigation
Have you hit the unit with any force? Could the G-Switch be possibly activated? Disconnect one end of loop. See if problem continues.
There are two reset wires..... have those been checked.
View Reply
View Thread →
© 2024 Rotate.Aero
