Mark
Mark
replied to the topic
DME - Distance Measuring Equipment
in
ATA 34 Navigation
If things are working fine for 10 minutes and then not..... it sure sounds like a component is heating up and then failing. I'b bet it is the indicator.
View Reply
View Thread →
© 2024 Rotate.Aero
