Mark
Mark
replied to the topic
DME - Distance Measuring Equipment
in
ATA 34 Navigation
The upper right section of this print only shows one 429 Data Bus coming from the left GNS.
Is there one for the right? It might not even be setup to use the right.
View Reply
View Thread →
© 2024 Rotate.Aero
