GNSS spoofing
5 months 3 weeks ago #1288 by dynamics
GNSS spoofing was created by dynamics
How can I find out if any an aircraft use GNSS navigation system? Furthermore what is the "time shift" which is recognized as a likely symptom of GNSS spoofing?
5 months 3 weeks ago - 5 months 3 weeks ago #1291 by Mark
Replied by Mark on topic GNSS spoofing
Do any of your aircraft use GPS as a position input to the FMS (Flight Management Systems)?
If so, you're using GNSS.
As far as "spoofing" goes, I would tend to think that this is a wartime issue where incorrect GPS information can misdirect aircraft and missiles.
FMS systems uses several position inputs. VOR/DME and IRS being two of them. GPS inputs are not required.
"If" a GPS signal was also being used (and being spoofed), a position comparison warning would alert the crew that something was wrong with the GPS. It is able to be deselected. If not..... a breaker can be pulled.
Last edit: 5 months 3 weeks ago by Mark.
Time to create page: 0.717 seconds
