Navigation System Failure
8 months 3 weeks ago - 8 months 3 weeks ago #1215 by dynamics
Mark, do you have any idea on which part of aircraft radio navigation system is prone to failure, based on your experience?
Last edit: 8 months 3 weeks ago by Mark.
8 months 3 weeks ago #1216 by Mark
Replied by Mark on topic Navigation System Failure
Antennas and antenna wiring. Constant freezing/warm cycles tend to wear on both the antennas and wires that connect to them.
If an antenna gets any type of moisture contamination, the constant freezing (expansion) will allow even more moisture in over time. This can lead to external fracturing or severing of internal connections.
Co-ax connector wiring becomes brittle. Either the center conductor breaks off the pin or the shielding separates from the outer crimp.
Time to create page: 0.665 seconds
