For Those Times When An Aircraft Gets The Best Of You
9 months 6 days ago #1162 by Mark
Have you ever had an aircraft problem that you just could not figure out? I doubt there is a mechanic out there that can say"no".
If you're beat down to the ground getting your head kicked..... post your problem here. Maybe someone can help you out.
3 months 3 weeks ago #1367 by peter.waters01
Help, I’m getting my ass kicked.
For the life of me, I cannot remember how the EGT thermocouple gang does it’s job. There are 4 probes in parallel all connected to one output on a CF6-80C2. If one probe is removed from the equation, does the temperature indicated go up or down?
3 months 3 weeks ago #1368 by Mark
rotate.aero/forum/troubleshooting-tips-g...40-thermocouples#613
Thermocouples create a millivolt output in relationship to heat. If you loose a probe or section..... the output will be "less". Your temperature indication will be "lower" than what it should be.
Time to create page: 0.724 seconds
