DME - Distance Measuring Equipment
2 weeks 6 days ago - 2 weeks 6 days ago #1438 by Mark
New member Krishan. I created a aircraft type section CJ2 for him and added Chapter 34.
From his email:
Now days I am facing DME issue on Our Cessna Cj2. DME installed Bendix king KN63
That the DME is working when we tune into  VOR it comes on the radio receiver panels only on the Bendex King display and does not show on PFD and MFD.
2. On ILS  the same DME function is displayed on PFD on both pilot and copilot side and the Bendex King display.
THE DME IS WORKING, unless it is separate for VOR and ILS.
For this thing we replace our KN 63 Interrogator but problem remains same.
And I also attached wiring diagrams....
Last edit: 2 weeks 6 days ago by Mark.
2 weeks 6 days ago - 2 weeks 6 days ago #1439 by Mark
The fact that you're getting DME distance display on both DME displays for both VOR/ILS, I would say this is not a DME issue.
From your prints, the DME indicators feed the Garmin displays.
I'm guessing this is a possible "Mode Display" issue.
If the Garmins have long range navigation, they usually display distance to the next waypoint and not VOR DME data. DME signals from the VOR's are being used, but not displayed. Crews need to know when the next turn is (next waypoint).
The crews normally will select LNAV for long range navigation. LNAV shows waypoint distance. Do the Garmins have a VOR selection for mode?
2 weeks 6 days ago #1440 by Emblemdhc
Sir there is only one DME tuned by two GNS 530 for selection NAV1 and NAV 2 there is sperate switch For indication  both PFD  and Bendix king indicator KDI 574  So first we tune DME   by No.1 GNS 530 there is  No distance and no audio tune heard Sometimes I noticed there is audio tone and no distance on KDI 574 And next step we tune DME by no.2 GNS530 there is distance on both PFD  and Bendix king indicator KDI 574  And audio tune heard  Next step now we Swap GNS 530 with each otherNow swap conditions And next step we tune DME by no.1 GNS530 there is distance on both PFD  and Bendix king indicator KDI 574  And audio tune heard  And we tune DME   by No.2 GNS 530 there is  No distance and no audio tune heard   But after 3/4 power cycle  DME Not showing distance and no audio tone by both GNS 530  Sometimes it show  distance on 1 and 2 selection by GNS 530  But sometimes not This system is only one of our aircraft not in any other so we can’t swap anything from. Another aircraft I don’t understand what to take next step now
2 weeks 6 days ago - 2 weeks 6 days ago #1441 by Mark
I downloaded and viewed a couple items from the GNS530 Pilots Guide.
Page 16 shows a power-up self test page which states that if you see a distance of 10.0 NM, the DME input to the system is functioning. Do you get this on both control heads?
I guess I'm still not understanding the problem fully. You stated when you swapped controls the problem followed?
You have proper ILS display and tuning which leads me away from the serial/data inputs being incorrect.
I would think the switching might come into play, I would like to be there to view the setup myself.
What is a 3/4 power cycle?
Can you post a vid of the switches (on your second print that you sent me) and what they do to the displays when activated?  One is a On/Off switch, one a Nav1/Nav2, and the last a Hold switch. Does turning off the DME during this power cycle  and then turning it back on make any difference?
2 weeks 5 days ago - 2 weeks 5 days ago #1442 by Emblemdhc
Dear sir Now we tune DME by GNS 530 1 and its show distance on KDI 574 and both display and tone is heard and when GPS is acquired by GNS530 is also show distance on it
Now we change we tune DME by GNS 530 2 and its show distance on KDI 574 and both display and tone is heard and when GPS is acquired by GNS530 is also show distance on it
But after 10 minute  on DME by Nav 2 its show no distance on KDI 574 and Both PFD
Now we select  test Frequency on GNS2 108.00 and start test using IFR6000 and rf level is -2.0 demIts show distance  and audio tone heard
Now we change frequency to 109.00 and show no distance on KDI 574 and Both PFD
Now we swap GNS with each other
  Now faulty (we assume) GNS 2 in 1 position  And start using IFR 6000 It’s  on 108.00 its show distance and tone is heard
On 109.00 there is no distance and no tone
110.00 there is distance and tone
111.00 there is no distance and tone
112.00 there is no distance and tone
113.00 there is no distance and  no tone
114.00 there is  distance  on KDI 574 and no distance on PFD and tone is heard
115.00 there is no distance and no  tone
116.00 there is no distance and no tone
   Now check in GNS 530 2 108.00 ok
109.00 no indication
110.00  distance / aural tone heard
111.00 no indication
112.00  no indication
113.00. No indication
114.00 distance / aural tone heard
115.00 no indication
116.00  no indication
 Meaning of 3/4 power cycle is power off 4 times.
Last edit: 2 weeks 5 days ago by Emblemdhc.
2 weeks 5 days ago #1444 by Mark
Same tester different frequencies, but with some you get proper indications - others not.
What airport are you at? Does the airport have a local VOR or ILS's that might be transmitting a DME signal also?
If so, what do you get on those (being that are active systems and not test box generated)?
Try different VOR frequencies other than .00 (116.60 or 117.30 for example).
Here's a list of active ILS's
2 weeks 5 days ago #1445 by Emblemdhc
I am at Delhi airport India ICAO  code- VIDP
Delhi airport has Tow VOR/DME station  Frequency 114.60 and 116.10  both are active station
Aircraft is Parked inside hanger so it’s only catch 114.60  sometimes
we check  with multiple frequencies but it not respond
for this reason we change DME interrogator with serivceable one and  same problem exists
now we have doubt on GNS 530 its may be  misbehaving
Is it possible junction box is misbehaving ?
2 weeks 5 days ago - 2 weeks 5 days ago #1446 by Mark
Two ILS's with DME.
It seems odd that certain frequencies work, but others don't. Verify the tuning wires from GNS-500 to the DME are all there. The data wires are also suspect. I'm also not sure what the KDA-689 function is. It's titled as a ARINC Serial Adapter. It sounds somewhat suspect....
Last edit: 2 weeks 5 days ago by Mark.
2 weeks 5 days ago #1447 by Mark
Look at these three wires....
2 weeks 5 days ago #1448 by Mark
The upper right section of this print only shows one 429 Data Bus coming from the left GNS.
Is there one for the right? It might not even be setup to use the right.
Time to create page: 0.951 seconds
