• Bleed shift on PW4000.
    Look at duct pressure around 80% N2 while accelerating and decelerating.
    As the engine slows down LP pressure drops off up to a point when HP air kicks in and drives the pressure back up again.
    For the write-up above..... that bleed shift did not happen in a timely manner. It finally shifted, but for a few seconds I'm sure there was some serious ass-puckering going on.
