• They are the most reliable! We use the crimp solder and seal splices exclusively at the shop I work at. I was considering buying a DeWalt 20V cordless heat gun , instead of always dealing with a cord, especially if its a repair out in the lot. Like you said in one of your other posts...its easy to burn thru the shrink tubing with a flame.
