engine 5
  • Mark created a new forum post in ATA 31 Indicating and Recording
    Noticed this intermittent fault. Problem has not been troubleshot, but I suspect a bad Air/Ground relay might be causing the problem. Started thread in Chapter 32, if problem is found to be elsewhere, post will be moved.
    Turned on hydraulics, problem remained. If you noticed, the right electrical pump did not come on. It was only after this quick video was completed that I had time to mess with the switch. If it was pushed "just right" the pump would come on. The aircraft needs the switch replaced also.
