engine 5
  • Later I'll compare to current strapping pin position, if it is still the same like previous reg., if yes, it is lucky for me because no other BIG work to do. If not, I have to look on the pin itself to find the current octal code.
    About the tools, can you give me P/N of it? Insertion and extraction.
    For the pins, I reckon, I just look on the P/N on the current pins (if I have extracted one).
    I will update to you once I settled this things.
    For now, many thanks tou you Mark for helping me.
