engine 5
  • Thanks Mark.
    Really appreciated it.
    Yes, It is Hawker. previous N registered is N825MS and now is under Philipines reg. and planned to dereg to 9M- reg.
    The problem is, I have no other reference or current octal code right now.
    What you mean is, I need to reverse the step, looking for which pin are inserted now, then compare it to new octal?
    BTW, should the pins on the rear TDR is same manner regarding of the aircraft,right? so I just simply use your docs uploaded previously.
